I have a 17 foot center console with a 90hp Johnson outboard motor. I noticed that the Cavitation plate is about 1/4" higher than the bottom of the transom, will this make a difference in any way if it were even with the bottom of the transom? I was going to lower it but then I realized that it is such a small distance that I would onlt be able to make it further above the bottom of the transom or about a 1/2" below it. The only other option I can think of, is to install a jack plate which is about $200. Is it really worth that musc to move the motor 1/4"? I was considering adding a Dole-Fin just to ensure the motor would not cavitate.
