Outboard Stands
Tinjum
What do y'all use for stands? Have Johnson 90hp and 110hp that need stands for and not quite sure what to buy, as both are pretty dang heavy, or if should build something. Would love some suggestions!
JimS123
There are designs online for OB motor stands. I have personally built a dozen or more stands, but for motors between 3 HP and 35 HP.
I guess you could go bigger, and a google search would probably provide specs. But my questions would be: Why would you need a stand? Why would you take it off the boat?
Regardless, at that weight you would need a hoist to maneuver it. The biggest motor I ever moved from one boat to another was a 3 cyl Evinrude 60 HP, and I wouldn't want to do that again.
cyclops222
I build them with 2 X 4 drilled & bolted together.
You could even buy and slightly modify a engine hoisting stand. Harbor Fright used to sell great cheapies. That lifted any car V 8 engine.
Tinjum
Just got the 90hp recently and it is on a pallet, and would be switching onto the boat instead of the 110 as the 110 will need some work and opener is soon. So would be needing a stand for one at the minimum.
Tinjum
An engine stand or a shop crane?
jbcurt00
Lots of info in here. Take a look around
Big Gee
I've built this one a couple of times. Biggest engine I've had on them was a 70hp 2 cycle Mercury, but I think with modifications they would hold something bigger.
  • Outboard Stand Rev A (2022_02_02 00_00_42 UTC).pdf
matt167
Quick and rough stand can be built out of 2 pallets and a couple scrap 2x4s.. quick and not so cheap method would be an engine stand with a plank bolted to it ( not tall enough for XL shaft )
Davetowz
I made an adapter plate for my automotive engine stand. Works great on my 9.9 and 35hp motors, probably not tall enough for a big motor.
BWR1953
My neighbor buddy welded up a tall stand for me made of 2.25x2.25" galvanized square stock which was leftover from when my garage was built.
Having it tall made it easy to pull lower units for water pump changes and whatnot.
I hung a pair of 70HP Merc 3 cylinder engines on it simultaneously, no problem.
airshot
The motors can be laid down without issue, no stand needed. You need a hoist to pick them up. Used a small chain fall rated for 1000# from Harbor Freight to lift and swap out my 85 hp and 70 hp outboard. Used an old pallet and my ATV jack with wheels to move them around.
