Warranty Period: | 07/30/1998 - 07/30/1999 |
When you write "pop the top off the outdrive...", what exactly are you referring to? Could someone post a pic? Also, would this be a simple procedure of popping it off, counting the teeth, and bolting it back on? No grease or oil to replace, etc.? Thanks!The very easiest way to make sure you know what gear set is either to pop the top off the outdrive and count the number of teeth on the gear set, OR, pull the drive off and turn the u-joint shaft.
The only accurate method on the manual shaft turning method is to see how many turns on the input shaft - the one with the u-joint, it takes to turn the prop 10 turns.
If it takes 20 turns to turn the prop 10 rotations then you have 20:10 ratio - which divides down to 2.00:1 ratio
If it takes 18 and 1/2 turns, you would have 1.84:1 ratio
If it takes 16 turns you have 1.62:1 ratio
And so on. Very accurate method each. Gear sets and number of teeth are also well defined and definitive. Anything else is a guess.
^^^Ok, so how do I rotate the driveshaft and count the turns of the prop? Specifically, could someone walk me through the procedure of rotating the driveshaft? Thanks!
Wow...yeah, I think I'll just operate on the assumption that it's now a 2.00:1 drive, and go from there! That's looks like a whole lot of mechanical work that frankly, I have no business tackling. LOL! Thanks anyway guys!Remove prop
Remove drive and have it held by or hanging from a fixture.
Move shift foot straight forward or to starboard and ensure prop shaft locks in place. Now rotate the drive shaft and ensure prop shaft turns as drive shaft is turned.
Mark prop shaft and drive shaft (may be easier to mark u-joint on drive shaft)
Rotate drive shaft counting rotations of each
