outdrive gasket question
mojokim
When reinstalling the outdrive what type of sealer if any should I use on the gasket? Thanks.
rodbolt
Re: outdrive gasket question
hello <br /> what type of outdrive?
crazy charlie
If it is a mercruiser dont use any sealant.I usually spread some grease on before I put the gasket on and I spread some on the drive too.Fills any tiny voids that there may be and helps the drive come off easy and the gasket too!! Charlie
rodbolt
hello<br /> on a cobra drive I use OMC adhesive M now known as super weather strip adhesive to hold the water passage oring in place and I wipe the face of the boot in the gimbal housing with perfect seal.<br /> the gasket I leave dry.<br /> good luck and keep posting
Trent
Things change guys......Iv been using loctite for the last five years or so. No gaskets on certain things. Works great!<br /><br />loctite.com
