krisnowicki
- Jul 11, 2007
- 1,172
I have had to replace the hose from the transom to the bellhousing for the alpha one gen II oil feed. the "gravity feed".So I got the right hose and was putting it on today. WhenI removed the old one a piece of the nipple came with it. I dont see how the nipple would come off. But it is not air/water/or oil tight. So here is what I am thinking.
1. I could try and patch the crack in he nipple with some jb weld or plumers weld.
2. I could change the nipple, But would this require taking the engine out and working on the transom from the inside. Which I would had to do for something as dumb as this little nipple....
3. Is there a way to just block off the oil passage and forget the bottle. That was it will be like the alpha gen 2's with out the oil check bottle?
Thanks in advance
Kris
Thanks in advance
Kris
