Outdrive not putting out power - 1988 OMC 4.3L / Cobra
crabby captain john
Re: Outdrive not putting out power - 1988 OMC 4.3L / Cobra
Just because an impellor "Looks OK" does not make it so. The PO ran her dry at least 1 time, probably more. An impellor is cheap, a water pump kit is only about $35. I change the impellor every year. A pump kit and thermostat every other year. If she overheats you will be dropping the LU again.
GA_Boater
For the time and money you have invested, not changing the impeller or pump kit is false economy. Like Crabby said "Looks OK" doesn't cut it. Anytime I drop my lower, the impeller gets changed, It's cheap insurance in my opinion.
