captainnate
- Apr 19, 2011
- 211
1972 mercruiser 120, pre-alpha outdrive
I took the outdrive off and replaced the impeller. How do I know that the gear shift shaft is in the right position? (Yes, I did put the boat in forward when I took the drive off.) When I first took the drive off the boat and turned it upside down the shift shaft fell out onto the floor. Also, I didn't try to line anything up in regards to the shift shaft when I put the lower and upper parts of the drive back together. I didn't see anything to align. I put the shift shaft back on through the hole after the lower and upper were back together. Is there something (cotter pin) that is suppose to hold the shift shaft in place? Thanks.
