Outdrive tight after steering pin and lower bushings replaced
Drivewayboater2
Alpha 1 gen 1 outdrive. I rebuilt my outdrive. Replaced the steering pin( top bushing as well) torqued to spec. Replaced the lower bushings too. After putting it back together it seems a bit stiff. Clearance in he lower pin is correct.
I can move it by hand but it seems a bit tight. Is this normal? Will it loosen up over time? Just wondering if the power steering will be compromised by this stiffness. Any comments would be appreciated.
alldodge
Depends on how stiff, stiff is but most likely it will loosen up.
Was the newer nylon bearing (item 4A) used?
Drivewayboater2
It moves by hand. Just a lot of mass to move I suppose.
yes new style bearing. Pricey bugger and it was a bear to install.
alldodge
Your probably fine. I would not worry about the PS because it's designed for a whole lot more load then a stiff pivot point
Pmt133
Did you hit down the ring with a mallet and recheck the clearance a few times? Mine took a few cycles of that before everything held and felt right.
I am also going to assume it was originally assembled with the nylon bushing?
