Outdrive up or down?
fabrickator
I’m new to boating and I restored a 1986 Reinell 17’ bow rider with a 3.0l OMC with OMC Stringer outdrive.
My question is should I tow with the drive in the up or down position? I’ve read with the larger Cobra drive to use the plastic ram clips. The Stringer has no rams and instead it appears to use an electric or hydraulic gear drive. Is there a transom saving device for this type of setup or does it not matter since there are no rams to leak down. IMG_9009.jpeg
rolmops
Towing should be done with the drive up so the skeg will not hit the road at bumps and such. If the skeg bottom is at least 9 or 10 inches above the road when it is down, it would be better to have it down while towing
Earl Cordova
When I had an OMC Stringer I towed with the drive up, stored it with the drive down.
Also had to drain the tilt housing after every trip because it sucked in water every time it was used.
Mc Tool
Looks like a good boat , I like them with a lot of deep uncluttered side so I can wave my fishing rod around and lean against the gunnels ....mine only comes up to my knee ...which makes taking a **** over the side interesting ....specially on the port side as Im right handed 😁
froggy1150
Master Chief Petty Officer
I tow mine up without issue.
I do put a small c clamp on the arched gear assy where if there were a failure it would wedge in the gear/sprocket. The order is drain plug in,clamp off, bats on... go 🚢 then when done i reverse that order. I never have bats on with clamp on. EVER
