Outside in the winter?
ricohman
I was planning on storing my boat outside this winter.
Beyond the usual winterizing and cover/tarps ect do I need to be concerned about the cold damaging the boat?
I live in Saskatchewan so it gets pretty cold here.
mpdive
Re: Outside in the winter?
I wouldn't think so. As long as it's properly winterized it shouldn't be a problem. Some drain all the water out while some take the extra peotection of adding antifreeze. I prefer the antifreeze with corrosion protection. You can always stick a little lightbulb is a safe place and leave it on at night. It actually generates some heat under the tarp.
jigngrub
It would help to know what kind of boat you have.
Bob_VT
Oh cold is horrible for the boat........ you need to arrange that the boat spends it's winter season in a nice warm climate!
Since that is a luxury I would never pay for........ I too live in a very cold area. In the past I have stored a few of my boats in the weather and I always DOUBLE tarped them I keep the bow high, plugs out, wheels off the bare ground and also used a frame under the tarps to keep them strong against the snow loads.
I keep my batteries inside and charge them monthly.
Yes, you do live in a cold area ;)
gt
if outboard or sterndrive, make sure outdrive is trimmed WAY down, to allow water to drain. Ice WILL split a lower unit housing. Been there, done that..
ricohman
I have an old Starcraft trihull with a 80hp merc.
But I have a new Starcraft Islander 221 with a 4.3 coming soon. I will most likely have to store both outside.
jigngrub
I have an old Starcraft trull with a 80hp merc.
I'll PM you my address and you can ship them down here to Alabama and I'll keep them nice and warm for you all winter.:D
I know quite a few Canucks that go the shrink wrap route every year after they get everything winterized, the shrink wrap really helps with the snow load.
H20Rat
A lightbulb for winter storage is a very bad idea... It will do next to nothing at -40, and poses a huge fire risk. (in more temperate climates a lightbulb can protect an engine when it drops just a little below freezing at night.)
Anyway, my current boat is probably going to spend its first winter outside this year. It will have a quick and dirty 2x4 structure built under the tarp to hold it up, followed by the form fitted factory cover, followed by a cheap plastic tarp. (those usually only last one winter, but help protect the expensive factory cover)
Bob_VT
Wow!!! Aren't iboat-er's nice!! :D A free offer!! Problem solved :)
ricohman
I guess you could work all the new boat bugs out of the Islander and have the motor broken in nicely when I come to get it!
jigngrub
It would be the neighborly thing to do eh?!
