Michael Lang
- Aug 14, 2013
- 30
1991 70 hp force
I have gone full cycle on overheating causes and still have overheat buzzer warning after Two to Five minutes of operation.
Replaced lower unit driveshaft seal, water pump bottom plate, gaskets and impeller ( stainless housing looks good).
Pulled power head off, removed exhaust plate replaced gaskets and cleaned complete exhaust chest, removed head,
and checked water jackets and cylinder walls and pistons (looked good) replaced head gasket and torqued per service
manual.
Removed bottom spacer plate copper pipe (no blockage) replaced gaskets and exhaust tube seal.
reassembled power head on motor leg.
replaced thermostat, thermo overheat indicator, new carb. (TC111A), new plugs and starter.
Bottom line motor starts right up runs really great, overheated in Two minutes yes the head and exhaust plates were
Hot could not touch.
Went to lake anyway and every thing set to factory specs, perfect hole shot, hit 35 MPH, then overheat buzzer again.
What can I do to find the problem? I need help.
manual.
