Overheated thanks to a plastic bag
thegodown
Re: Overheated thanks to a plastic bag
It turns out that my insurance DOES cover damage caused by plastic bag covering the water intake. Yeah for Allstate.
The adjuster is sending over a marine surveyer. I was thinking about the list of things that I know should be checked. If any of you can think of any additional item, please add them to the list:
Engine (obviously)
Exhaust manifold hoses
Exhaust flapper
Seals in the Alpha outdrive
Alpha water pump impeller
bruceb58
Your new engine is going to have more horsepower just because it is newer. I don't buy the "different horsepower" affecting you that severely. As long as both engines are synced in RPM you will be fine.
muc
"Retired" Association of Marine Technicians...
seen a few inner transom shift cables go bad because they rest against the Y pipe during a overheat.
good luck muc
