I have an overheating issue on a 1977 merc 140hp. I replaced the raw water pump but still am having problems. I want to confirm that the water pump is delivering proper flow after my replacement.
How much flow rate should i see at the t-stat intake hose? I definitely see flow when I run at 2000 rpm but I am not sure if it is sufficient. Trying to rule this out before replacing the manifold/inspecting the exhaust shutter.
One other piece of info. The engine runs cool if I hook a hose directly to mufflers on the lower unit, hot if I run from tub of water.
Greg
Greg
