john hennessy
- Oct 23, 2013
- 21
small block ford/ mercruiser 888
due to a lack of money my cooling system is somewhat rudimentary, the water comes from the impeller in the stern drive,(new impeller kit)and runs directly to the new circulating pump, prior to this it tees off and a reduced line feeds the risers, there are no restrictors between the risers and the manifolds.
at the thermostat housing there is a very simple housing, the thermostat is a 160 degree stat, above that, the water passes to the senter riser manifolds, there is a small hole to bypass the stat, about 1/4".
test 1.
this is a reconditioned engine and i have filled the cooling system with water and sealed all the hoses, i then pressurized the system to 20 psi, there was an initial drop op 2 lbs which i atributed to the hoses swelling, it held 18psi for 5 hours.
i then pressurized each cylinder with an air line and rotated the engine by hand, holding it at tdc against the pressure, at no time did the guage on the cooling system change from the 18 psi. this convinced me that there was no leaking of combustion pressure into the cooling system and no leaking of water into the combustion chambers or cylinders.
i felt confident to put it in the lake.
test 2.
first run showed almost no reading on the temp guage, in fact i disconnected the sender and grounded the wire to test the guage which prooved o.k. i replaced the sender, no change, the exhaust manifolds were getting a little too hot to touch but the thermostat housing was slightly warm, i concluded that the thermostat was still shut due to the coolness of the housing preventing water from going to the manifolds, the risers were cool due to the raw water supplied to them.
test 3.
i removed the thermostat, the second run showed the same almost no reading on the temp guage but when i increased the revs above 3500 - 4000, the temp guage rise was immediate, at 200degrees i shut the throttle and idled the engine, there was a lot of steam comming from the thru transom exhausts acompanied by a lot of water.
within a minute, the engine temp guage was reading 150 degrees and falling, i repeated the test and the same thing occured, i returned to the dock at 4000 rpm closing the throttle at the no wake zone bouys about 30 yards from the dock, by the time i idled to the dock, it was down to just below 150 degrees.
the questions
if i drive the boat below 3000 rpm, it does not get hot enough to move the gauge above 100 degrees(the first mark on the guage)
if i take out the thermostat, allowing raw water to flow unrestricted through the engine, the engine overheats, where is all this hot water comming from?
if i install the thermostat, the engine stays so cool that the thermostat doesn't open, and the engine stays cool to the touch?
i have not fitted a clear hose from the thermostat housing to the exhaust manifolds, this will be my next test.
does the team think that air or combustion gas is accumolating behind the thermostat causing it to stay shut and due to this the guage sender is dry and won't read, as i stated earlier, there is a small bypass next to the stat
any help will be much appreciated, John.
test 1.
test 2.
test 3.
the questions
