TwoRivers
- Mar 10, 2010
- 344
Once again I come seeking wisdom, guidance and understanding.
Working on a 99 Johnson 200hp two stroke. (J200PLEEN).
Changing out seals in lower unit and replacing water pump.
I removed the shift shaft cover before removing the water pump.
The impeller was frozen to the drive shaft and I had to pry on it from two sides.
When it broke loose the plastic key (white one) fell down into the shift shaft compartment and disappeared.
I've turned the unit in every direction and tapped the housing with wooden blocks and rubber hammers but no luck.
Every attempt to find and remove it has failed.
If left in the bottom of the lower unit will this hurt the gears?
Any suggestions for removing without taking the gear assembly out?
Thanks in advance.
rob
Thanks in advance.
rob
