Hey guys. Figured this would be the best place to post this. I am in the process of removing the old swim ladder from my transom and putting a new one on. What do I need to use to patch the 4 holes from the old ladder that are just above the water line where the bolts went through the transom? I've found Marine epoxy, cement and stuff like that and was wonder if that would work to just put that in the hole and let it dry, then put more to get the outside of the hole even with the transom surface. Would that work? I don?t really care if there are a couple small holes that are a slight different color white (boat is white) than rest of boat because they are on the transom just above the water line and will not get noticed much. What would you guys recommend using?
Thanks!
Thanks!
