Hey guys, after a long day i finally replaced both upper and lower water pump gaskets and impellor and re-installed the lower unit. <br /><br />i started the motor in a bucket full of water and it started rite up and ran like a charm, but, no water was coming out the tell-tail!!! <br /><br />Motor was running fine but no water! All the water-pump stuff is done. <br /><br />Is there a thermostat i can clean? if so where is it? any other things to check for? <br /><br />its a 1974 Mercury 500 50HP. thanks again, Neil
