Pee tube
mayorj1227
86 25hp evinrude, water pumps great. Nothing out of pee tube...line from block is clear
Is the motor overheating ?-----Did you have lower unit off to replace impeller ?------Was the copper water tube installed into the exhaust housing BEFORE you put lower unit in place ?
oldboat1
Try compressed air to clear the tell-tale, or a piece of weed-whacker line. Use the line like a drain auger -- twist and push.
Crosbyman
stick a shop vac on the pee hole (adapt the hose accordindly) if you find no blockage
if nothing apply air pressure
btw it pumps but...did you inspect he impeller coud be just a piece of rubber went up the wtare tube and is stuck
