Penn Yan 265 Hull Drain Location?
Status
Not open for further replies.
captainhank
I'm a new 265 Hardtop Owner and I have no idea where the hull drain plug is located. The first examination of the engine compartment and all other compartments is a little overwhelming to someone like me who has only had experience with less complicated boats with much less electronics and plumbing. It will all make sense as time goes on but at the moment I'm a little shell shocked. The boat has been shrink wrapped for the preceding 15 years.
Henry
dingbat
The garboard plug is typically located just above the keel on the transom
JhuddsOhana
Henry
Our 30' Penn Yan Twin tunnel drive has the drain plug midships just in front of the engines. Right beside the keel. Not sure if yours is the same.
Status
