Penta SX - new steering cable won’t go through the end of guide tube of power steering
reef55
858BC05A-63AC-42E9-8874-59A024CDA64E.jpegI am trying to install a new steering cable, everything seems right but the end of the cable just won’t go through the white plastic ring at the end of the power steering guide tube. Is there a trick to get it through? Thanks!
If you have the old shaft, you can cut the end off to use as a guide.
or find a socket the same size as the shaft, push in a bit to hold the lip on the seal open and guide the shaft in.
reef55
Unfortunately I already threw out the old cable. So is the white plastic ring a split ring that can be expanded? Or is it just a matter of perfectly lining it up?
read the second line of my post.
Ayuh,.... The 1st thing to do is Grease the shaft, 'n inside of the tube,.....
Otherwise, you'll be doin' this again in a year or two,....
reef55
I’ll grease it, thank you! Any other tips for getting it through that white plastic ring?
Ayuh,..... Never dealt with one, with an o-ring like that,.....
Do know that the most common failure is binding/ corrosion, from a lack of grease though,......
I might try bevelin' the edge of the cable end slightly, to help spread the ring out to where it's gotta be,.....
shoving a socket in the hole that is the same size of the shaft to hold the lip on the seal open while you push the shaft thru as stated in post #2
reef55
Thank you Scott, I have been trying that for over an hour, maybe I don’t have a socket that is right. I found one the same size as the end of the cable, and tried pushing it in from the other side, but it would not go through from that end either.
reef55
Well, I finally got it to go through. I lightly tapped the cable clamp part (metal) with a hammer and it popped through. Thank you everyone!
