Pertronix Coil hookup
dezmond
Hey Everyone.. I decided to get myself a new coil. The Pertonix Flame Thrower 3ohm part number 40611. I have to go through all my wiring on the boat and clean up all contacts, corroded wires, old wires etc. I wanted to ask something.
Since I will have my main wire harness out and checking it over, can I add a new 14g wire to go from my new ignition switch back direct to the new coil? That way when it is switched to the on position, the coil will have it's 12 volts? Also any advice from you guys/gals that have put one of these in your boat would be great :)
Thanks
Dezi
Fishermark
Would that work? Sure, but is unnecessary. If you have an electric choke you can add a wire from there to the coil and bypass the resistance wire.
dezmond
No. No igniter. Still want to use points and condenser. That's ok right?
dezmond
Hmmmmm So thats not going to work :(
What would be my options now?? Can I bump down the voltage then for the coil or is that not a good thing?
stonyloam
Ayuh,... The points need the lower voltage, or they'll burn up,....
It is a 3 ohm coil, so it should work without the resistance wire. The 1.5 ohm coil would require the resistance wire. So it should br OK.
dezmond
So it being a 3 ohm coil I will NOT burn my points? I can still use the points and condenser? Also I should still get he 12 volts needed for the coil correct? I just don't want to fry anything that's all :)
Thanks
Dezi
bruceb58
Out of curiosity, why did you pick this coil? I would have replaced with standard coil.
dezmond
Wanted something that if I decided to switch to EI I could... Can I still use this coil with my points?
dezmond
Just got off the phone with Pertronix. Told me to measure the Ohm's from the old coil and the ballast and it should be close to the 3.0 that the flamethrower has which means I will not burn out the points. If it is under, I can hook it up to the existing wire that has the lower voltage to be safe and no issues.
That's some good news for today :) Now off to check all the wiring!!!!
