pics and progress on engine rebuild
83mulligan
Re: pics and progress on engine rebuild
I hope it is not too personal to ask but what kind of money did you put into redoing the engine? I have a 165 that has 1400 hours on it I am sure I may have to rebuild it at some point but right now it is purring along nicely.
Jason
I'd love to know this too, even if in PM.
Fishermark
It's still running great 83mulligan - I don't really know how much I spent. The best thing to do is ask your local machine shop what their various shop charges are - how much to bore, etc - whatever things you think you will need to have done. The parts themselves are parts that can be easily purchased at your local auto parts store. (I'm talking about the internal engine components, not the externals like starter, carb, etc).
83mulligan
i'm kind of mechanical, but by no means anywhere near a mechanic. Is it feasible for someone like me to take my time, spend a winter doing it using the manual, this website and some friends who know their way around engines better than me to rebuild my engine? I like getting into projects, just never tackled anything like this. Same engine by the way, in a slickcraft SS-206.
Don S
Sure, it's possible, but don't expect it to go perfect and expect everything to just fall in place. It takes a lot of work and attention to detail to fix something properly.
Ayuh,...
Your Best bet would probably be to find a local Machine Shop,...
Have them do the tear-down, cleaning,+ Mic'ing....
Then they can point you to the parts you'll need,+ can do the machine work...
I'd have them assemble it to the Long Block configuration,...
Then you could do the rest of the swapping,+ installation....
Slickcrafts are Fine hulls from the 1s I've seen...
My Boss has a SS-195 that We dropped in a 350EFI, alpha Gen.II....
mthieme
I wouldn't recommend it unless you had someone to look over your shoulder occasionally.
There are also some special tools you will need too (torque wrench, valve spring compressor, puller, ring compressor, timing light, tach-dwell meter, straight edge...just a few that come to mind).
83mulligan
I want to go through the process myself. Slowly, with lots of help. Someone looking over my shoulder from time to time when i need it. I have a torque wrench :). As well as a friend or two that are mechanics that would assist me with it.
Don S
Then go for it, it will either work or not.
A couple of suggestions.
Start a NEW thread for each question. DO not just keep going on forever in the same post and try to cover the complete job.
Those threads with hundreds of posts don't get read all the way through and finding the newest question can be a real chore, so they usually never get answered.
I have at least 10 torque wrenches, and thousands of dollars worth of tools. But without knowing how, when, where, why of those tools, they don't help much.
Fishermark
That says it all right there! Go for it. :) It really isn't too difficult. Take pictures and draw diagrams as you go. It's amazing how easy it is to forget where a bracket goes or how a part goes back on - don't rely on your memory. Buy a big box of zip lock sandwich bags and a stack of 3x5 cards. Label the parts - keep the nuts and bolts together. Read the manual and books - ask questions. Have fun!
83mulligan
ah well, its a fishing boat and i have a nice high thrust kicker, so if i blow up the engine I can always just have a 7 mph trawler with a wide open deck, lol. Next winter is the time to get into the engine I think. I have enough going on with the boat already as evidenced by my other threads. Thanks for the inputs, if the rest goes well I may give it a shot next winter.
alumi numb
hello,
looks great! i am an ol chevy six enthusiast from way back. :) used to design custom kits for them :D even write magazine articles on the inline six, history, performance and mods, etc. [blush]
achris sed:
"Also, did you reface the rockers? If you don't they tend to slide off the valves and damage their posts. Had it happen to me... Not nice...."
good tip, but actually... you dont have to reface them all as a rule... but u should inspect each one for a U-shaped marring that the valve tip creates on rocker tip after many miles of use. well, hrs in this case. or the wear pattern can be a cupped area favoring one side. in any case. i would not use any rocker with any valve stem tip marring. :eek:
for me personally, i would also not reface them. reason is because if the rocker tip is that worn, usually so is the rocker to ball base in middle of the rocker where it tips back n forth as the cam pushes on it.
these are the same rockers as any chevy dealer sells. so if u havent, replace any marred. if it were me, i would toss old one and replace all 12 rockers.and... all new rocker balls.
also, if it were mine i would only use brass components in ignition system: cap n rotor. i would not use the old marine plug wires, as i would without a doubt run the Magnecore KV8.5s... racing wires that r super efficient and... i would also run the MSD electronic coil. and a GM plug. i would also run the MSD 6A ignition module. and a tach. if dist is HEI u can get an updated coil from MSD
i run a 250 chevy six in my 83 van. it has ported heads, back cut valves, rv cam, KV 8.5 wires, MSD HEI, tach, etc. runs super nice! starts within about 1/4 revolution off starter. my other 250 is a solid lifter 300 hp six with windage screen, and crankshaft scraper. studs hold head on. and piston comes above the deck ".035 [past gasket] for an 11:1 CR! sweet sounding, guys have mistaken it for a V8. it does has 'the sound!" runs a 600 holley 4-bbl and pulls real...nice. i designed and built the windage screen, crank scraper, and the 4 bbl set up.
and another thing... i would get some cam lube and put some under rocker tips, and on valve stem for start up. also be sure to put some on the rocker ball and the ball seat. and the push rod tip area, too. then pour some engine oil on each valve rocker set up prior to start. then put on valve cover. i would also pre-oil the entire engine before i cranked it one revolution. and i would be sure to use a new fuel pump. ac-delco would serve me fine. even if with water sep too. and i would have the timing spot on. perfectly timed. ez to do. set it all off of #1 cyl and have crank set a BTC point, then set distributor. and after break in oil out, then use light to fine tune timing.
as if this wasnt enuff to think about... if it was mine... i would have plastiguaged the the new rod and main bearings to crank. the outside evelope is .0025 max, or it may be .0035 max on the big side [loose]. but while u have added new bearings u didnt mention u reground the crank. so i would want to tighten the rods n mains up to about .0015 - .002" and that will give up both a quiet engine, and a long rod life. if rods at .0035 now, u will have talking rods soon.
oic, u still have pan off, so best bet is to ck these running clearances. and DOUBLE. then triple check your timing gear alignment pin marks to align properly. be sure u put oil into the oil pump, too. if u didn't rotate the long block there, and un bolt the oil pump cover and pour in some oil. it will prime it. it needs to be primed prior to start up or u can and prob will score some bearings... [ouch!]
also: on all of my inlines i crank them first with no ignition. this lets oil pump ensure all bearings wet with oil. 6-10 revs. 2-3 revs at a time. crank, stop, crank, stop, crank, stop. igniton ON, then crank it to fire. then i add fire. the inline 6 cranks is LONG. and they will be dry and running before oil gets there. this will kiss the metal parts of bearing and crank journal and a premature wearing will take place... ie short rod life. [been there done that!!]
the engine should be set up to go right to 2000 rpms within first revolution or two. if not u can eat cam lobes. none of the err, err, err, wont start... err err... wont start... heck u cant tow a boat. lol ~ run engine at 2000-2500 for first 30 mins or so, so as the heat soak it all; on 1st start up unless cam is OE. and i would also install cam lifter dry. this way u can set each valve and get it to sit in the middle of the piddle valve travel. then when u start it up all valves will be perfectly adjusted. i never adjust hydraulic valves after first fire up... they are always adjusted dry... and they run perfectly. :D otherwise TOO messy.
be sure u have cam lube on cam lobes, fuel pump rod lobes and end, and... bottoms of lifters. u cant mix hydraulic lifters on use cam lobes. so if old cam u have to have same lifters in each boss... or new ones. they will eat the lobe otherwise... almost everytime. :eek:
then drain ur break in oil, change oil filter and put in fresh oil. u r set then to head to ramp.
well, u may have already done this stuff or most of it. if u need any help, u can contact me. hope she runs like she looks.
these are things to consider for ur marine 6. and all bolts on. good tech, too.
regards,
lakester :cool:
so does all of this apply to the 153 also?
Fishermark
alumi numb - this is an old post from 2007. It would be a good idea to start another thread or your question will not be seen.
