Pics of yet another project (updated)
deputydawg
I decided that I didn't have enough to do, so I built a wood stove for my shop. When I started this I also decided I needed a better work bench. I know a guy that un-packs products shipped in large sheets of styrophome so am going to insulate the shop walls with that. Found some old wood lap siding that I will sheet the inner walls with. <br /><br />Pics of stove.<br /><br />
<br /><br />
<br /><br />
<br /><br />It kind of made a mess of the rest of the shop. I can't believe I stored all of this junk on and under my old work bench! Hidden somewhere in here is an old set of gym lockers I use for power tools, my welders, and a car.<br /><br />
<br /><br />
<br /><br />
<br /><br />
ehenry
Re: Pics of yet another project (updated)
You project looks just like mine.....A need to clean up and throw out project ! ! ! ! !
Ron G
How long will that drum last?your shop looks about like mine :)
heycods
Dont believe I would have posted pix 4,5and 6. I put a wood stove in my shop and it sure is nice.unless you get 5ft away from it then your frezing to death. ;) With the temps we have had this year I havent fired it up. Only used the fireplace in the house 1 time.
deputydawg
Stoves like this I have made in the past, the drum has lasted 8 or 10 years. This one is patterned after a friends that he uses on his alcohol still (for racing fuel only) :rolleyes: <br /><br />I usually build them one drum on top of the other. Bottom drum is for the fire, the top is a heat collector. <br /><br />Last night I burned a few cardboard boxes and a few sticks to burn the paint off of the drum. With the doors open it still raised the temp in the shop about 10 degrees. <br /><br />My old shop heater was an amana electric range. I turned on all 4 burners and the oven. Opened the oven door and put a fan on the door. That worked great but was kind of expensive.
jsfinn
Deputy - I think you forgot something in your shop...<br /><br />There ain't no fridge for beer!
OBJ
Yeah....sure....alcohol still...for racing only......and what the heck you doin' in my garage???? :D :D
treedancer
I noticed two things missing .Hazardous placards and fire extinguishers. :D
dolluper
Is that stove for heat or moonshine :p :D
ZmOz
I just use a paint can with some holes drilled in it, and a few ounces of burning methanol inside. I've got insurance! :D :p <br /><br />Of course, it rarely gets below 50 in there...
deputydawg
Today I was struck by a thought. <br /><br />As I was lighting a fire getting ready to work on my manly space I thought.....<br /><br />If you have ever included in conversation "my friend used it to cook moonshine" or any sentence dealing with close friends making hooch....you probably ARE a redneck. <br /><br />Same probably goes for using a 50 galon antifreeze drum for heat.
Nos4r2
Good way of getting more heat out of one of those DD- put a slightly wider chimney on route it along one wall at a slight angle then bring it through the roof at the other end of the workshop.<br /><br /> You'd be surprised how much warmer it'll be- we used to do the same thing in the buses we lived in years back-kept them real nice and warm.
CN Spots
The first 4 feet of your hotrod looks great. :D <br /><br />The rest kinda looks like an open air debris garden. :p <br /><br /><br />spots
davemaxi1970
Is that tyre in the picture legal!! or is it a racing slick?
KaGee
Thanks for posting DD. Makes me feel much better about my basement. :p <br /><br />Thumbs up on the red-neck wood burner... hope you used plenty of duct tape! :D
