Re: Pin hole in gas tank
If you know how thick your floor is,know were your stringer is,split the diffrence over the stringers.Mark it,take a drill,put some tape to dep,drill holes at each cornner to get a true marking,remark.From there,use a circle saw,set the blade at the right dep,back out a hair or two,cut up your floor over the stringers deid center.<br />NOTE*Pump out as much fuel as you can before you start.Move the boat were you don't mine a gas spill.Over fill the tank with water a bunch of times.After doing so,add a bottle of Dawn dish soap,wash all gas that over flows out the tank and wash down around the boat.The left over gas will come out of the vent and fill line when flushing.Dawn dish soap will break the gas down some what.
