DeepCMark58A
- Aug 17, 2015
- 3,030
I will stick to my Windsor engine and single screw over an outboard. People are intimated by having to work a rudder.
The color means nothing. Read the labels & use the stuff with propylene glycol & corrosion inhibitors. Not the RV drain stuff.the pink RV stuff clearly states for plastic pipes (not for engine internals). I use it to flush my RV. But have seen boat dealers use it for winterizing.
I was using this Merc -50 stuff cause it had corrosion inhibitors and never had any problems. The pic below shows what happens at -40C. It got slushy but could still shake it about. The jug never expanded. Even though it didn't go solid, after seeing that I started flushing and left the internals dry/drained.
I am thinking the same when I buy my next 26' CobaltSolved the problem years ago……went to outboards
