piston rings for a 1956 fastwin 15?
1946Zephyr
Re: piston rings for a 1956 fastwin 15?
Yea, actually, the mark will be on the cam that opens the points. You'll see where it says TOP and that is where the heel of your points will be centered at, to make the adjustment. The hole in the flywheel is positioned where that marking is. The center of the flywheel might cover it, so you wont see it, but having the opening above the points, to where you can adjust them and insert a feeler guage, should put it in the right spot. Make sure you only turn the flywheel in the clockwise direction.
While you have that little cover off, slowly turn the flywheel in the clockwise direction and take a look at your coils. Make sure they aren't cracked on the insulation. If they are, then you'll need to consider replacing them.
Compression should be even, between the two cylinders. No more than a 10% difference. 90psi or better is good on that model.:cool:
levi_tsk
Ensign
will it thow the points out if i turn it counterclockwise? i i think i have turned it that way before you said something :(
tx1961whaler
No. That's just the way the water pump turns. Rotate the flywheel by hand clockwise and the rubber impeller vanes will get in the right direction.
levi_tsk
Ensign
oh ok well the lower unit is off so i guess it doesnt matter then but ill get in the habit as i dont wanna mess it up thanks
