kenny nunez
- Jun 20, 2017
- 3,505
Actually your and all automotive engines are left hand rotation when viewed from the flywheel end which is standard rotation. Quite often single engine straight drive boats are right rotation. It can really get confusing especially if the starters are rear entry, as on jet boats and straight inboards.
OMC and Volvo did have 170 hp engines while Mercruiser only had 188s.
Mercruiser used 2 barrel Holleys on the 188s. As I stated before your engine should work out as long as you have the correct carburetor. From what I can see it has a Ford automatic transmission kick down lever so it is a automotive carburetor.
Sierra Marine #18-7635 is a 300 cfm that they show as a rebuilt.
Also Sierra # 18-7636 is a 500cfm model. You may have to also pay a core charge. Sierra only shows these carburetors that I posted for the OMC engine. For some reason they do not show any Holley 2 barrels for Mercruiser.
There are several places on the internet that specialize in rebuilt marine carburetors.
