Pitch perfect
jlh3rd
yep...got it...some props won't work on some motors because the prop hub diameter does not match up to the gear case diameter.....regardless of prop diameter, gearing, or pitch. A small matter but semi costly if not recognized.
Comment was snarky....I felt.
Just trying to help...
75Qwest
Update, I purchased a spitfire 15 4 blade. First run with the new prop I can hit 21 mph with 25 gallons of fuel and 3 adults. 5600 rpms. My rpm range is 5000 to 6000. I think I found the right prop. No cavitation and I can hold a tight turn at 20 mph.
