Plane question
LubeDude
Re: Plane question
Originally posted by AFishin69:<br /> Again I will attempet to raise the motor up a notch to see if that can create a better angle for thrust.
Raising the engine is NOT going to change your angle! You need to get some wedges to change the negative angle, I think that is the general concensus of the members replys. After you get the angle changed you may need to raise the engine some because of the setback. Go ahead and raise it another inch while you are a putting in the wedges because I think you will need at least that much more, but you HAVE TO INSTALL THE WEDGES!
