LaqueRatt
- Jun 27, 2022
- 469
Just wanted to add that my hot glue repair eventually failed. It was just fine until I figured out the previous owner had somehow got a bunch of crap in the tank and I had to drain it and clean it out. Funny thing was after flipping it upside down and blowing compressed air in through the filler opening that glue started getting soft. So much for being impervious to gas. Went to the hardware and found a brass reducer, but since the elbow doesn't have a standard taper on it, it would only grap 3 or 4 threads before getting tight. That's when the light bulb went off.
There was this super thick funky rubber washer under the elbow. Must have been nearly 1/4" thick. Took it out and cut a gasket out of some rubber/cork gasket material I had. Now it cinches up nice and tight because it's grabbing some fresh threads. So anyhow, don't use hot glue. At least not the clear stuff.
