maineiac5586
Master Chief Petty Officer
- Feb 14, 2009
- 801
I have 2 lower units. One is a v6 lower unit one is a v 4
I noticed they both have play when wiggling driveshaft side to side. Noticed with and without water pump and housing either installed or removed. Gear oil looked fine. I pressure tested the v6 lower and couldn't get over 2 psi as I hear air leaking from driveshaft area. I have only worked on 60 hp and smaller omc and never noticed any play. Does this suggest something is wrong with these 2 lower units?
