Play in steering then found this..
Dieselmadness
Standing behind the boat I can move the drive left and right a couple inches…checked the final housing etc and all looks good, then found this play in the linkage. Question is, what are these two parts called and which one looks to be bad…not sure how it’s assembled, still trying to find a diagram but figured one of you guys have dealt with this before, any ideas? ..(video attached.) BTW, 16’ Sea Ray with 3.0 and Alpha one gen 1
  • IMG_3120.mov
pretty sure that is supposed to move. looks like the pilot section of the steering actuator
Ifishmuskie2
What was it like when you had it on the water?
I have outboards but they seem loose ( too easy to flop around) when on land but in the water they are good.
Grub54891
That’s normal, it has to move for the power steering. Have you checked the steering pin for play at the top of the gimble housing?
or are you getting the normal bow wander at slow speed?
Dieselmadness
So, haven’t had it in the water yet but I just happened to notice the play when my son moved it..just seemed to flop around a little, however when I run the engine and move the wheel, there is virtually no play at all in the wheel, I turn, and the drive instantly moves. I DID check the steering pin on the gimbal and there was no play whatsoever. We’ll see how she acts in the water after I replace all the bellows etc. I’m currently trying to find the hydraulic line for the trim that runs from the pump to the transom, another thing I need to get fixed before she hits the water.
Thanks for the insight guys, very much appreciated!
