Please explain fuel system/pump 50hp Evinrude.
JB
Re: Please explain fuel system/pump 50hp Evinrude.
Well, that explains why the cylinder is scored. You have a broken reed valve. Fix that before you start a major overhaul.
tashasdaddy
Thats what i think,also.
jnaarnold
Where is the reed valve? I did not think this engine had them.
John
rolmops
Ok, what your model number, as none of the 86 50hp had vro, according to BRP they had this fuel pump http://www.iboats.com/18_7352_Fuel_...8118897--**********.433900912--view_id.174141
here is a picture from my 88 50hp same motor one is fuel pump the other is hose routing.
I beg to disagree.
My 1986 50 horse RECREATIONAL came with a first generation VRO. The type that would change the mix between 1:50 and 1:100 dependent on the rpm of the engine.
There are not many 50 horse engines left with that VRO. Lots of them set up because of lean mixture problems
I replaced it with a traditional fuel pump,based on my "keep it simple, stupid" principals. The Commercial 48HP still had the regular fuel pump
JB
The reed valves are located between the carbs/intake manifold and the crankcase, John.
jnaarnold
Took the reed plate out, all look great and are closed, no carbon or any build up around them. Shined a light behind them could barely see any light at all. Could not get a .003 feeler in there, I assume that is ok? The other night, I held two fingers over the lower carb and she idled, that was with the lower unit submerged in a tub of water and muffs on also. Tonight she would not idle, with just the muffs, no tub. Only if I hit the prime/choke solenoid. I will be getting my pistons soon. I am going to tear the motor apart next week.
John
