Dawson130
- Feb 13, 2018
- 62
So I just purchased a 95 nitro bass boat powered by a 115 merc. Took it out today and motor was really hard to start and have taken it out 3 times now. Motor seems to lack power. Haven’t been able to get it on a plane and when it is running it’s been coughing a lot. Long story short i found a fuel leak in the main line right before where the oil mixes with the gas. I squeeze the primer and it’s a steady spray out of the hose. Would that be causing all of the symptoms? Also would it affect me getting on plane? Boat also came with 2 props. Currently has on a quicksilver laser 2 prop with a 26 pitch. The other is a 23 and looks like the oem prop with a 23 pitch. Should I put the original on instead? Any help is appreciated! Thanks in advance.
