Please help me. Need some advice.
thumpar
Re: Please help me. Need some advice.
If you have a Napa close by go there.
tazrig
They should. Have them look up the part number for you. If they don't have one you can always order one here on iBoats at ibaots.com or just call: 1-800-869-1686
They really know their stuff
thumpar
For an alpha one water pump kit???
Yes. I used to get my Alpha pumps from there and now get my bravo pumps from there. They carry a ton of Merc parts in stock. Their part numbers are the same as sierra.
tazrig
Good to know, I never would have guessed.
Manny503
Ok how do i post pictures hers!???? /:
I recently bought a 1990 Monterey 19footer. And its been hard finding info on this boat. Im new at boating. So my boat comes with the 4.3 L Chevy V6 motor and a 260 mercruiser sterndrive. I recently changed the motor oil and someone recomended me to use 20W 50. So i did. But i wanna make sure thAtll be fine before i take the boat out for the first time. I dont want to use the wrong oil and burn the motor. :( and so i also changed the oil for the sterndrive 260 mercruiser. I went to west marine and they recommend me to use a high viscosity oil so i got 80w 90 for it. Please help me. And tell me if im ok to go . I dont mind changing it again if im using the wrong oil. Thank you very much in advance for all your help. I appreciate it. Im a rookie at this.
Ok guys thank you very much.!
Manny503
So i called NAPA and they dont carry water parts here in California :( anyways i found a store like 15 miles from my house not bad.!! And second: so i took the upper unit off as well and you guys should see how filthy that was i even found some metal parts in there. Anyways im going to clean that amd add new grease. Hopefully im able to put it back together because it looks quite complicated :( do you have instructions on how to put it back???? There are some loose parts that i think are the shifting gears or something , anyways plz send me the instructions if you have any..! other wise ill have too you tube it . Thank you.
Manny503
is that suppose to be loose like that??
tazrig
Manny,
Here is the Mercruiser Service manu@l for your Alpha one drive. It goes over everything you'll need.
Boatinfo - Mercruiser Service Manual nr. 6 - 1983-1990 - R, MR, Alpha One & Alpha One SS Sterndrives
Assuming you still have the 1990 4.3L Mercruiser, here is the Service Manu@l for that also.
Boatinfo - Mercruiser Service Manual nr. 7 - 1983-1993 - GM V6 Engines
achris
More fish than mountain goat
So i called NAPA and they dont carry water parts here in California :( anyways i found a store like 15 miles from my house not bad.!! And second: so i took the upper unit off as well and you guys should see how filthy that was i even found some metal parts in there. Anyways im going to clean that and add new grease. Hopefully im able to put it back together because it looks quite complicated :( do you have instructions on how to put it back???? There are some loose parts that i think are the shifting gears or something , anyways plz send me the instructions if you have any..! other wise ill have too you tube it . Thank you.
That worries me.... Photos please.
As for instruction on putting it back together... have a look in the stickies, I've got a bunch of videos on putting the drive halves back together and also putting the drive back on the bell-housing...
Chris.....
Manny503
thank you sooooooooo muchhhhhh i really appreciate all your help.... thank you....!!!!
Manny503
Manny,
Thank you thank you... So much... This is gonna help me alot...!!!!! I really appreciate what you do for me man.. Thank you very much!!!!.....
Manny503
For some reason is not letting me post pictures but ill keep trying.!
achris
Post your photos to a photo site (I use photobucket) and then post the links to those photos in between the image tags...
(Remove the spaces I've put in)
[ i m g ]www.whatever.com\your_picture.jpg[ / i m g ]
That will have those pictures appear here, just make sure they are no bigger than 600x800.
HTH,
Chris.....
Manny503
HTH,
Chris.....
Ok i will do that.
Manny503
HTH,
Chris.....
Hey question..: so i got the impeller for the water pump, so two questions., how to i determine which side the impeller turns??? And when putting the new impeller, is it suppose to enter really tight??? Or do i have the wrong impeller?? Is there a certain way to do it???
Thanks.
bspeth
Watch the vids,Manny. Cant go wrong if you look and listen.
achris
Gasket goes on dry.
