Please help with HPDI issues
Stilletto
if everything is in spec but still running too rich, then you may need to try another ECU
did you have the injectors tested/cleaned and make sure they are the correct ones
I sent the injectors to Brucatos. He said that they worked and flowed correctly, and replaced the orings. They did mention that one had a short in it, which they hadn't seen very often, but that it disappeared after cleaning. Mentioned that could be caused by injector driver or could just be a fluke since it disappeared.
Stilletto
Anybody familiar with the crank position sensor and the pulser coil? I checked the timing with a light, the timing was rock solid in neutral but as soon as i put it in gear it jumps around a bit....
dingbat
Typically one and the same.
Sends crank position (pulse) to the ECU for timing purposes. Very sensitive electrical “noise”
If it’s jumping around, it’s typically a bad sensor, but a wiring problem can induce noise into the circuit as well.
Stilletto
The HPDI has the Crank Position Sender and the Pulser coil...I am waiting on a replacement coil, will update.
Bugzilla46310
Mr. Obvious here. 3 pages of posts and I did not see any proof that the air filter is good. It is noted on the photos of the plugs, and if it was verified good, I misses it.
99yam40
I have never seen an air filter on any outboard motor.
could that have something to do with no one mentioning one in the thread, except for Mr. Obvious?
Stilletto
Replaced the Pulser coil, didn't fix it. I have the Crank sensor coming this weekend.
