Re: Please tell me my outdrive isn't toast
ok, my outdrive is back together. I had a local shop do the final reassembly. They charged me $90 to check the drive bearing preload, measure and shim. Since I replaced the drive tapered roller bearings and the upper shaft bearing and race they said the shiming did change slightly. So all in all not horrible. $365 for new yoke, yoke seal, tapered roller drive bearings, upper shaft bearing and race, impeller/water pump kit, new tension washer and lock nut, all new upper seals and new gimbal bearing. So now I have to pull the old gimbal and replace. I'll do that in the next couple weeks. I can't believe how warm its been here. I think summer is going to come around pretty early this year. I'll be ready!
