Re: Plug wires
You must remove the flywheel, then the armature plate. You only need to remove the four phillips head screws near the centre and the throttle linkage to detach the armature plate. Then flip it, remove whatever tabs are holding the wires in place, pull the wires out of the ignition coils and install new ones.<br /><br />But you really don't need to be replacing them unless they're cracked or broken. They're not a maintenance item like in a car. You'll have to replace them with metal core wire of the same diameter.<br /><br />You know to torque the flywheel to spec when installing and to use a proper puller for removing, right?
