Points wiring
rtoomey641
Hi Possible bad petronix want to try points does the wire go to positive or negative side of coil 485 Mercruiser Thanks
salty3rd
I would stick with elecronic ignition, points are a PITA.
achris
More fish than mountain goat
ifyoumustgowithpointswhichinmyopinionisastepbackab out40yearsthenthepointsconnecttothenegativeoftheco ilandthepositiveofthecoilconnectsto12vviaaballastresistor dontforgetthecondensor Cheers
bruceb58
I guess I will be the one that answers your question....negative. I also don't blame you. I didn't put Pertronix on an engine I used to own to replace points because of the reliability issue.
Bt Doctur
If you can tie your shoes ,you can install and maintain a points system.Be sure to include the resistance wire or the ballast resistor in the circuit.
