polishing aluminum hull and have gouges.....with pics
jtrom
I'm leaving my bottom hull bare and want to polish the area that is visible. I have some gouges that look too deep to sand. Anything I can do besides live with them?
oops!
Re: polishing hull and have gouges.....
fill them with gellcoat.
scuff up the scratched area...clean with acetone
mix up some gellcoat paste
fill area....(this can be done with a bondo spreader just swipe over the scrape)
let cure....sand flat....to 1500 grit....polish...........gone !
jtrom
Hey Oops, my fault for not saying this is an aluminum boat...your method is for FG right?
Yacht Dr.
Yes it is ..
Pics please :)
YD.
jtrom
Here they are.........Is there anything I can do if I'm polishing this area?
boatnut74
You can feather them out using increasingly finer grits of sandpaper. I did this once and I think I started at 400 then worked my way up. Polishing will get rid of the small scratches from the sandpaper.
jtrom
So basically just sand,sand,sand!?
Bob_VT
You have WAY too much time on your hands......... stop over thinking the hull. Just do what you want and move on........ no one will notice the gouges only you will.
The sanding of the aluminum will remove the outer layer and some places will corrode (discolor) sooner. If it was my hull I would just move on.
Go ahead and start moving back from the scratches and from about 50 ft they should be gone........ and being on the bottom of the hull I have found out that the fish really don't care! ;)
Ayuh,.... Sand those gouges out, 'n yer likely to sand Through the hull....
It's only about .063 to start with...
jtrom
Re: polishing aluminum hull and have gouges.....with pics
The boat is a 1959 Starcraft and seems thicker than todays boats. I'm not looking to sand them completely out, just minimize them.
