harringtondav
- May 26, 2018
- 2,480
Yes. Get a dual action/random orbit 6" sander. Use wet discs. You can find fine grit discs. For your boat I'd start at 1500 grit and work your way up about 300 grit/pass to around 2500. Finish hand sand with Meguiars Unigrit 3000 wet.When i wet sanded I went up as far as 3000 grit.
Then put a foam polishing head on the sander and finish with a high quality polishing compound. ....I like 3M Perfect-It Machine Polish 06064, and then wax.
Then every spring hit it again with the polish and wax. The gel coat will look new until you sell or scrap the boat.
