Pontoon Re-build
DDW_OR
I have a pontoon with a 8x16 deck. the deck is rotten and i am planning on a total strip-down and re-build.
I tried to add photos and got the following error "You are not authorized to create or remove attachments."
I am on Forestry Form under the same user name
Mod EDIT: link removed
jbcurt00
Avoid posting re-directs and links in the 1st post of a topic.
You need to make 3 posts before you can post pix.
Make 2 more and follow the suggestions found here
http://forums.iboats.com/forum/forum-rules-and-guidelines/9938375-photo-upload-tutorial
Avoid option 3, and for sure avoud using Photobucket here or anywhere else online.
Just post something like
For pix 3
And then you'll be good to go. Also note in the pix tutorial that there is a size limit on uploaded pix, @700KB IIRC
DDW_OR
talked to a guy that has a motor for sale and he stated that there is a coating i can put on the plywood to keep the moisture out
For pix3
jbcurt00
Please remember Iboats is an onljne retailer and avoid posting their competitors
DDW_OR
now lets try some photos
this is how the pontoon looked when i lived in AZ
plan to change the layout
i will use a grid to explain where things are.
example, 6-3 is a removable table in green
Motor on left
small white circles are swivel seats, 2-1, 2-7, 4-7, 14-2, 14-6
small green circles are for shade umbrellas
red rectangles are bench seats
simple kitchen is at 7-7
captains council is on bottom edge
ahicks
Looks like an awesome project! Like your ideas regarding floor plan as well. Not so sure about the shade umbrellas, struggling to visualize those. But might warm to that plan after seeing them in place.
DDW_OR
the pontoon is going to be used by my dad and me. he is 85 and I want to keep him shaded and cool
the umbrellas are the pole type used on patios
the pontoon has been put on hold for now. other projects have higher prioritys;
3000 feet of fence
3 lean-toos to add to the pole barn
chicken coop
Firewood
greenhouse = two harbor freight 10x12 placed end to end, with all mods and re-enforcement
etc,etc,etc,etc,etc,
DDW_OR
changing the layout
adding a bathroom/changing room
the round circles are for removable chairs
may still use shade umbrellas, like at the beach or for tables
MRS
Yes said when I lived in Arizona where you at now?
DDW_OR
the floor
plywood or patio deck flooring ( like you would use for the deck at your house )
carpet or hard surface
