popping out the carb.
nick9118
hey guy need help. i have a mercruiser 3.0 the carb. is popping and blowing fuel out. would the intake gasket it do this?
Bt Doctur
Re: popping out the carb.
More like a bad intake valve sticking or hung up. The popping is either compression blowing back or a misfire or water in the fuel/carb.
Do a compression test
nick9118
how do you check if the a valve? and well old oil make the valve stick?
JustJason
Check via a compression test.... if you have little to none in 1 cylinder then it's probably a bad valve.
jj
dan t.
an exhaust valve not opening will cause these symptoms,possible lobe worn off tne cam, broken or backed off rocker arm ,pull the valve cover and spin the motor over while watching the valve movement
good luck
nick9118
o just to tell the motor still starts and run's just rough. would it run with a stuck valve?
JoLin
Yes, it'll run depending on the cause. If it's a valve problem, the valve is more likely to be "sticky" (slow to close because it's gummed up) rather than stuck solidly open. Or, the valve face is burned and not forming a good seal in the head. Or, a valve return spring is busted. As stated, do a compression check first.
Another common possibility is that your ignition timing is off and the plugs are firing while a valve is partially open. That'll cause the same symptom.
Ayuh,...
As I said in your Other thread about this Same Subject,......
Change the Fuel Filters,+ try it....
droptheline
isnt it funny when someone doesn't like the answer they get, they look for another one, start with filters and work your way up in price from there.
nick9118
lol sorry about that droptheline i couldn't have this thread i am new at this anyways i pulled my head off today and bewteen the 2nd and 3th the gasket was busted thanks for the help...
