Grandad
- Jun 7, 2011
- 1,504
Re: Positive flotation in 'bigger' boats . . .
One point that complicates things is that for flotation to be of net benefit, it has to actually displace water, meaning that until it is submerged, it's only added weight, however slight. Putting all the flotation low in the vessel, if that was possible, would ensure the greatest benefit. The problem that I see, is that once submerged, balance becomes critical and the boat will likely roll over. The heavier superstructure without flotation will of course hold the boat upside down while passengers are left clinging to the slippery hull. So the trick would be to provide as much flotation as possible in the gunwales to form a stable perimeter. Next, your stern is far heavier, so the bow maybe the only part sticking out of the water, unless you pack flotation around/above the engines which is usually not practical. Ya, I think on a larger boat, I'd invest in an emergency inflatable or carry/tow a RIB that could also be used for gunkholing in the shallows. - Grandad
