ForceEightyFive
- Jun 1, 2011
- 20
Newbie here...Ive been scouring past threads but havent been able to achieve correct diagnosis of the problem on my outboard. When I do a cold start the motor runs strong at idle. However when I shut it down it is difficult to turn back on again and when it does the idle is extremely rough (sputtering) and will die. I rebuilt fuel pump-no change. Theres also no leaks from tank to carbs. Spark is good as is compression. Also the primer bulb will not get hard. When I crank the motor over strong with the plugs out alot of gas vapor will come out of bottom two cylinders but only a small amount on the top one. Idle setting on all three carbs are at 1 1/4. Im thinking is the carbs need to be cleaned...any ideas?
