postings not showing up as response
Bt Doctur
Past few days my post to a question does not show up , if I click on the post is shows my response but does not show a response indicated ,
see post "470 not pumping" or "7.4 alignment"
alldodge
Not exactly, if you are using the old style rear mounts you need the double spring washer,and the fibre washer can rotate if you are using the newer style, "knurled end" you use no washers or a thin SS one to set the rear height.
This is your post on the 7.4 alignment (post 6), was there another?
I post again after yours
southkogs
Not sure I'm following ya' BT - I see all of the posts. They were made within about 10 min or so of this one.
Bt Doctur
the post is there I made but when you go back to the page the post does not show with my name.
the 470 thread shows 6 responses but there are 12 responses , the persons who made posts 7-12 are not shown.
theres no way the original poster can know there is a response unless the actualy click on their thread.
