potential ignition problems
jrem123
Hey to all: I'm a Force user but they all suggested I post here because apparently the engine uses Merc ignition parts.<br /><br />I have a Force 85 hp 1986 that has compression and spark, runs fine at low r's, but won't get up to speed. The power band just fell off the cliff one day while pulling a skiier. The prop isn't spun, has power at the low end, but seems like it's starved for gas when I get on it.<br /><br />The fuel pump diaphram is okay. Pics of the spark plugs are at http://jrem.webhop.org/2686.jpg <br /><br />I'm thinking it's a plugged carb, although I did the seafoam deal trying to clean it out, to no avail. <br /><br />Someone stated that there might be a problem with ignition coils at higher rpms, so I'm asking here if someone can please help.<br /><br />Thanks, John.
cistn
Re: potential ignition problems
hAVE THE STATOR DIAGNOSED
Bob H.
Coils usually show signs of cracks on the older engines. Usually rear their head after the engine has warmed up. If it bogs coming out of the hole the carbs are dirty. If Seafoam didn't clean it up you'll need to split the carbs and clean'em good. Removing all of the welsh plugs is the best way to clean them up. You can usually get by without removing the welsh plugs but it's a crap shoot. Coil cracks are usually quite noticeable on the older Mercs and Chryslers.
