Potential Purchase
DC20
Looking at a 2000 Maxum with a 350 MAG MPI Mercrusier I/O. Motor was replaced in 2008. Problem is I see rust around the bottom of the oil filter and dip stick has rust on it, there was maybe a 1/2" of oil showing on the dip stick after the sea trial (looked a bit thick). I wondered if the filter was original, salesman said original was black so it must have been replaced at one time. Salesman also said dip stick rust is common on a boat that sits. Boat has seen very little use over the past 2 years. Do I run? Do I run a comp check and run new oil and filter for a short time and repeat and hope it's all good? I would be getting a very good price on the boat but is it worth the risk? Oil pressure seemed good on the gauge but don't recall the number.
See my other post on Termites:eek:
Your input please:)
Re: Potential Purchase
Ya but was it between Add,+ Full,..??
Boats that sit in saltwater Rust,... It's probably surface rust that could be cleaned,+ painted...
A thorough Inspection should be done on it..
Only You can answer that...
DC20
The rust was on the inside, on the dipstick.
Stachi
run away from this boat..there are better to be had
DC20
Probably should run, but the low low price of 8400 is very tempting.
Ayuh,... Is it Still a Good price when you figure in the potential $2500. for another motor...
Atleast do a compression test...test drive,, etc...
DC20
Did the sea trail all ready, ran good.
I have been w/o a boat for almost a year now so....
Problem is a boat this size with this hp is normally way out of my price range, this one is within reach.
This motor was put in new in 2008, factory motor.
