I currently have a johnson 140hp (1987)loop type. The problem is that after about 40 mins of use it drops its power and sounds like it is running on 3 cylinders. I have checked for water in the fuel and have re done the carbies and checked for blockages. non of the above appear to be the problem.It mainly happens once motor is hot however it has occoured once when the engine was cold it would just not run properly. Can any body advise of a possible problem.
