dennisknight
- Dec 4, 2002
- 12
Okay, heres one for all you fixer people. I have a Evinrude 35hp 1983 rope start. Ran great until recently, now will only run at idle both in gear and out of gear. Starts on first pull all the time, good spark to both cylinders. Checked and swaped new plugs and wires. CD2 replaced and carb rebuilt both less than 2 years ago. Will run on bottom cylinder only, but top cylinder does add to rpms, sounds like it anyway. Compresion is 130psi in both cylinders. Did all Clymer checks on ohm readings on coils. All check out OK. Pulled intake manifold, reed block looks brand new, no sign of burning, warpage, etc. Appears to operate fine when rope is pulled. Both plugs appear wet, although the top (trouble cylinder) is probably wetter than the bottom. New gas in tank, No arcing to ground when run in low light. What could be the problem? My questions are: If you get good spark (arc at least ½ inch and strong blue color) from both cylinders can the CD2 still be bad? I've replace two of them in 18 years and I seem to remember that when they went bad, I didn't get spark to one or both of the cylinders. Can the pack throw off timing to one cylinder? If I had a fuel pump or carb problem wouldnt it show up equally in both cylinders? Any and all help, suggestions, ideas, ect would certainly be appreciated.
